How Hard To Change The Cps Unit.
Old Nov 24, 2007 | 08:42 AM
PAVEMENTMAN's Avatar
PAVEMENTMAN
I Am New To Diesels And Was Wondering How Hard It Was To Change The Cam Position Sensor. I Get A Slight Rough Idle When The Motor Warms Up And Think Its The Cps.
Old Nov 24, 2007 | 08:55 AM
Action4478's Avatar
Action4478
Most likely its not the CPS,,, but anyway..
Look ...here.....
Usually rough idle when warm is IPR o rings....
Is the Crankcase full ?
Are you due for an oil change?...
Old Nov 24, 2007 | 09:02 AM
PAVEMENTMAN
Thanks For The Info. It Dont Really Have A Rough Idle It Just Lopes Slightly When The Engine Gets Warm. It Dont Do It All The Time. If You Touch The Throttle For A Sec Then It Clears Up And Idles Smooth Again. Any Ideas.
Old Nov 24, 2007 | 09:52 AM
Action4478's Avatar
Action4478
When it's idleing rough, unplug the ICP connector & see if it smoothes out ,, while its unplugged , look to see if the sensor has oil leaking from it,, if so replace it...
Old Nov 24, 2007 | 02:28 PM
PAVEMENTMAN
Were Is The Icp Sensor
Old Nov 24, 2007 | 03:32 PM
plowhand's Avatar
plowhand
Playing in the Dirt
ICP Sensor = front inboard (vallely) left (drivers) head, three wire connector.
Old Nov 24, 2007 | 06:15 PM
2 stroke man's Avatar
2 stroke man
ya it will be a big difference if its not the icp. the icp is where the 10k mod is done. look up 10k u'll find a pic. promise.
Old Nov 25, 2007 | 07:54 AM
Action4478's Avatar
Action4478
PIC ..... here.....
Old Dec 14, 2007 | 09:21 PM
PAVEMENTMAN
How Hard Is It To Change The Icp. And Is It Were The Wire Plugs In.
Old Dec 14, 2007 | 09:24 PM
Neal 97 250's Avatar
Neal 97 250
easy to do it is where the wire connects to.
Old Dec 14, 2007 | 09:26 PM
PAVEMENTMAN
How Does It Come Out. Unscrew And What Size Is It.
Old Dec 14, 2007 | 09:37 PM
Neal 97 250
It has a 10 mm bolt that holds it in then you can take a small flat screwdriver and pry it out
Old Dec 14, 2007 | 09:40 PM
PAVEMENTMAN
I Am Talking About The Icp. Not The Cps.
Old Dec 14, 2007 | 09:49 PM
Neal 97 250
OOps sorry man. I believe it unscrews from the head. My bad
blrman1962
Dec 11, 2016 10:42 AM
Doc Wright
Sep 22, 2016 11:00 AM
Hussler
Sep 19, 2015 03:54 PM
Drenalin
Jul 7, 2014 06:17 PM
firebug
Mar 8, 2006 08:01 PM
