injector codes
Old Nov 24, 2007 | 06:09 AM
Royson12's Avatar
Royson12
injector codes
What do all the injector codes mean. I have a set of fairely new injectors, coded BB, wondering what the difference the codes make. I thought they would all interchange.
Old Nov 24, 2007 | 08:29 AM
seizure911's Avatar
seizure911
The injectors codes have to do with the amount of fuel delivered and opening pressure. I think the bb injectors are for a 6.9
Old Nov 24, 2007 | 08:35 AM
PLC7.3's Avatar
PLC7.3
Check out the list on ........
http://www.mwfi.com/dieselPage/ford_69.htm
http://www.mwfi.com/dieselPage/ford_73.htm
In basic essence the 6.9 and early 7.3 can use the same injectors, the 92.5 build date IDI non turbo engine and later use a different code (E), the 94 turbo (factory) use a different one again (code G). The pintle dimentions and opening pressures are different.
