302 Leaking Antifreeze.. HELP!!
Old Nov 24, 2007 | 12:35 AM
eco's Avatar
eco
Maybe you ought to hook up a coolant system pressure tester.
Pump the system full of pressure then look for the leak. Quick, easy and accurate.
Old Nov 24, 2007 | 07:38 AM
cumminsdieselfreak's Avatar
cumminsdieselfreak
SPONSOR
Oh yea i forgot to say that my heater works very very good!!!! Didnt know if this helps....
Old Nov 24, 2007 | 09:17 AM
flareside_thunder's Avatar
flareside_thunder
I second that Eco...that's how I found my leak....cept I made my pressure tester....
JR
Old Nov 24, 2007 | 09:23 AM
Steve's Avatar
Steve
What he should do is very carefully and methodically dry off the coolant with paper towels. Then with the engine cold, (more likely to leak when cold) pressure test the system like you guys suggest. He can rent a pressure tester for free at Autozone.
Old Nov 24, 2007 | 09:26 AM
cumminsdieselfreak
SPONSOR
Check out my newest post about finding the leak!!
Old Nov 24, 2007 | 10:00 AM
TheRoadVirus's Avatar
TheRoadVirus
Finding the leak and the general area of the leak are different things .
