Can leaving the Block Heater pluged in do damage?
I insalled a Webasto heater in my F-350 and it comes on 30 min. before I start and the truck is warm. I also do alot of sitting on location and in the winter time you need to stay warm. I just hit the buton and keeps inside warm for 30 min. Best $2000.00 spent. no idleing truck and usees very little fuel.
I heard the Webasto's use a lot of juice from the batteries, that on some trucks the batteries were dead when they went to start them. How many times have you had to get a boost?
Webasto
when I use the Webasto in the morning I have no problem. You can only run on location for 1 hour at a time and start truck for 15 min to charge batteries. I learned the hard way on my GMC when I had one in that one. They say if you run it for 15 min. you should run the truck for 15 min. but I have not had a problem in the Ford yet. I amd up here in Alberta Canada and it can get really cold in the winter and have not plugged my truck in yet. The Webasto only uses 0.6 liters per hour. You would have to fiqure that out in US gallans but it not much. I will put one in my next truck.
Actually you are not required to use the block heater unless it is -10 F or lower if you are using the proper oil for your winter temperatures.
If you are running for the winter 15W-40 it is recommended to use the block heater when the temps are expected to be 20 F or less.
Be careful not to use any timer other than a high-amperage (heavyduty) one. The others will melt into a blob of useless plastic due to the high current demand.
Mo1
How long did it take to put in. Was your truck tied up for the whole day?
$2000.00 that's a lot of money, could pay quite a few monthly power bills with that by plugging in the block heater. Do you live in some bush camp where they don't have power? Certainly there must be even generators there, that you could plug in your block heater.
Webasto
Took about 6 hours. I use it more when I am sitting on location watching rig crew work. If I were to idle to stay warm I would use half to three quarters of a tank a day. With the price of fuel it pays for it self pretty fast. If you go to the dealers they charge more for the unit and install but if you go to the Webasto dealer it not as much. Down in the US you could probley pick one up for less.
#28
#29
Hey Mo1
How's it going? Just wondering if before you bought your Webasto, did you also look into the Espar heater, if you compared the two and what the difference was, that made you buy the Webasto. I heard that the Espar is a little cheaper in price. Also heard that the Espar has a few built in safety features such as auto shutdown when battery voltage gets low so you can still start your truck - that sounds like something you could use on your unit, so you don't have to keeping boosting your truck.
