died while driving turns over no fire
Old Nov 23, 2007 | 06:32 PM
toddweaveraev's Avatar
toddweaveraev
here is the entire sad story. 1990 f150 5.8l 4wd
the altinator burned up and burnt some wires in the process.
I went junking and found the wires i needed. The egr wires (3) and the (3) wires that megre with them for a total of 6 wires all spliced together. The only problem i had was the wires were not the same colors. After some process of elimination I finally got it runnung great. I was on the test drive and the truck was running perfect. I went to a couple of stores and was headed home when BAM it shuts off like i turned the ignition off. I wrestled it off the highway and got it towed home. It will turn over but will not fire at all. I can't imagine it is related to what I did any ideas?
Old Nov 23, 2007 | 07:19 PM
subford's Avatar
subford
When you first turn on the key does the fuel pumps run for one second and then shut off?
Old Nov 23, 2007 | 07:25 PM
quicklook2's Avatar
quicklook2
the ignition actuator may be the problem.
Old Nov 24, 2007 | 11:53 AM
toddweaveraev
yes the fuel pump turns on for a second
Old Nov 24, 2007 | 12:51 PM
subford's Avatar
subford
Have the TFI Module tested at an auto parts store.
If OK then I would look at the PIP sensor, Ignition Coil and the wiring in the Ignition circuit.
Old Nov 25, 2007 | 12:33 PM
dagray3's Avatar
dagray3
pull the codes before you throw any money at it.
