1978 - 1996 Big Bronco
Drivers Side Window 1988
Old Nov 23, 2007 | 05:40 PM
plapczynski's Avatar
plapczynski
My Step Son is bringing over his Bronco for work in the morning. Someone broke out his drivers side window. He has picked up a replacement from a junkyard. I checked both my Chiltons and Clymers manuals and there was no info on it that I could find.
Any hints/tips on replacing the glass?
Thanks,
Paul
Old Nov 23, 2007 | 06:04 PM
lostin90s's Avatar
lostin90s
remove interior panel . Loosen the bolt(behind door panel )& screws(on door in jamb area) holding the vent window frame then move enough to get glass in. After clean out slide glass in place put window crank/motor arm in chanel . and tighten vent window back up Check window up down before you put all back together. Good luck
Old Nov 24, 2007 | 07:50 AM
plapczynski
Thanks!
Paul
