Sponsored by: Auxito
starter problems
Old Nov 23, 2007 | 09:20 AM
lref1's Avatar
lref1
starter problems
Since it started getting cold and wet, when I try to start my 1997 F-150 w/ 4.6 engine, there is a clicking noise from the engine compartment. At first I thought it was just a corroded battery terminal, but I have cleaned these and the clicking still remains. It acts like a solenoid is going bad. Is there one located in the engine compartment and could this be the problem? So far I can still start the truck, because the clicking will eventually stop and then the engine will turn over.
Old Nov 23, 2007 | 09:50 AM
sowder's Avatar
sowder
check all your wires and clean the ends of them at the starter too. I had a plug in terminal at the starter that was corroded bad.
