tire size?
Old Nov 22, 2007 | 08:27 PM
Scotty_O's Avatar
Scotty_O
tire size?
i got a 96 f150 xl and i want to put some bigger tires on it...right now it has 235's on it and i'm wondering what size will fit without putting any kind of lift into it
Old Nov 22, 2007 | 08:30 PM
302 F-150's Avatar
302 F-150
I know you can fit 32's with some slight trimming to the front bumper. Depending on the width, they may rub on the radius arms.
Old Nov 22, 2007 | 08:38 PM
msb71's Avatar
msb71
Is it a 4X4 or 2WD?
Mike
Old Nov 22, 2007 | 08:46 PM
Scotty_O's Avatar
Scotty_O
it is a 4x4
Old Nov 22, 2007 | 08:48 PM
Dean88's Avatar
Dean88
32's will fit, but I recomend 31's, becuase they will still rub the radius arms.
Old Nov 22, 2007 | 08:55 PM
1989BIG6's Avatar
1989BIG6
hey guys, if the truck was a 2wd, would you still say a 31 would fit?
and i think the stock rim is 7"wide, whats the widest tire that would fit on that rim?
thanks
Old Nov 22, 2007 | 09:03 PM
Scotty_O's Avatar
Scotty_O
do you think the 31's would rub....and do you know what 31" would be in metric
Old Nov 22, 2007 | 09:09 PM
sly22guy's Avatar
sly22guy
32 should fit fine, alot has to do with your backspacing. I know of a guy that runs 34x9's with no lift, not sure of his back spacing though
Old Nov 22, 2007 | 09:10 PM
1989BIG6's Avatar
1989BIG6
i know the 31's wont rub on the 4x4, the guy that lives across the street from me has had them for years and never has a problem...
i am concerned with rubbing on my 2wd even though i have had a guy tell me id be okay... i just want to try and confirm from others..
i also found out my stock rims are 7.5 wide so the 10.50 tires should fit on there.
anyone for the rubbing on the 2wd??
Old Nov 22, 2007 | 09:11 PM
Dean88's Avatar
Dean88
My 31 x 10.50 only rub the radius arm if I crank all the way, and even then its only slightly. You can run 35 x 12.50's in the back with no lift, (which I also used to do), but then your 4x4 will be useless.
I don't think you can buy 31 x 10.50's in metric, but if you could it would be a 305/65 15 (or something like that, I really can't remeber)
Old Nov 22, 2007 | 09:14 PM
1989BIG6's Avatar
1989BIG6
thanks dean
Old Nov 22, 2007 | 09:47 PM
lostin90s's Avatar
lostin90s
Even the trucks from factory that had 31's (I had 2 new ) Would buff paint off rad arms.
You could go P2657515 which is basically the 31' but little narrower . Which my truck had from factory. Don't forget to reset posom (center speedo) up in articals and specs tels you how. later .
Old Nov 23, 2007 | 01:50 AM
1989BIG6's Avatar
1989BIG6
got ya... and yes, that was on my list of things to check how to do
thanks
Old Nov 23, 2007 | 05:46 AM
s1120's Avatar
s1120
31 10.5x15 fit no problem at all. They came on some of them. 33 12.5's will fit, but may need to shim the front bumper a bit. Remember if you go taller, it will need more power to turn them. So I would recomend sticking to the 31's unless you got good power out of a 5.8L, or regear.
As for metric size a 31 10.5 would be a 265/75r15. Or as close as it comes. Most metric tires are P rated though. I think your better off with a C rated 31 10.5
Old Nov 23, 2007 | 12:27 PM
17fordguy's Avatar
17fordguy
i run 31 10.50 on my 96 2wd stock ride hieght f150 and theve never rubbed but there not on stock rims so im not sure if its makin a difference or not.
