build
Old Nov 22, 2007 | 12:58 PM
factory594x4's Avatar
factory594x4
Question build
What is a good head, intake and carb set up for a 221? Will a newer aluminum intake work, or will the ports not match up? Can I run gt40 heads or will I lose all port velocity? I want to keep the 221 for the gas milage, but a little more get-up-&-go would be nice.
Old Nov 22, 2007 | 07:37 PM
havi's Avatar
havi
I'll have the Roast Duck
IMO, look for an old 260 4bbl set-up. Or swap a 302 6 bolt and appropriate trans. in its place, but note you need 7" spacing motor mounts, so those need swapping too.
BTW, what vehicle is this for? I believe the 221 didn't start til 1962.
also, the compression ratio will drop too much with 302 heads on the 221.
I have a 221 in my '62 Meteor and like the 221 for what it is, as you already said.....mpg. Nostalgia is nice, too.
Old Nov 22, 2007 | 08:29 PM
Beanscoot's Avatar
Beanscoot
I believe the (rare) 260 4Vs used a manifold that was virtually identical to the 289 4V. Since this is a small motor, how about trying a 255 intake and heads? They have unique oval small ports and an aluminum (2V) intake to match. The exhaust pattern is the same as all the small bocks though.
I think the intake runners on a 221 are indeed smaller than the 289 and 302. I don't know how important this mismatch would be with an intake manifold designed for the latter though.
Old Nov 22, 2007 | 10:04 PM
51dueller's Avatar
51dueller
Just did a quick search for intake gaskets. They are all listed for 221-302 motors 62-76 so the intake should fit.
Old Nov 23, 2007 | 07:43 PM
baddad457's Avatar
baddad457
I doubt any 289/302 head will work on a 221 block. The 221's bores are 1/2" smaller than the 289/302. You'll run into valve to block interference.
Old Nov 24, 2007 | 04:06 AM
HemiEater's Avatar
HemiEater
just leave it as it is. you can't have both gas milage and get up an go.
