coils
Old Feb 21, 2002 | 08:13 PM
grays31's Avatar
grays31
coils
what does a stock coil put out 10,000 20,000 i don't know and if i were to get a new coil what kind should i get for my 1990 300 with cat back exhaust k&n air charger throttle body space.
Old Feb 21, 2002 | 08:33 PM
thelonerangerxlt's Avatar
thelonerangerxlt
coils
Grays31, your stock coil puts out around 30-35K volts. A good aftermarket coil will put out around 50K volts. The pre-HEI ignitions (points) were about 20K volts.
There are many brands to choose from: Mallory, Jacobs, MSD, Accel, etc. Take your pick. Make sure that you get one for electronic ignitions. With a hotter coil, you can open up your sparkplug gaps to .050"-.055". Then you can put on a set of low resistance sparkplug wires. And then......
Old Feb 21, 2002 | 08:59 PM
grays31's Avatar
grays31
coils
what would u use I'v been told Pertronix Flame Thowers are good but a need some more opions.Please.What did you mean when you said And then...
Old Feb 21, 2002 | 09:00 PM
grays31's Avatar
grays31
coils
Also give me some voltage on some coils Flame thrower makes 40,000 and 45,000. What about msd,jacobs,accel ect.
Old Feb 21, 2002 | 10:40 PM
Dumbtruck's Avatar
Dumbtruck
coils
If you go to summitracing.com or jegs.com, you can look up just about any coil ever made.
Old Feb 22, 2002 | 04:29 PM
wildjon300ci's Avatar
wildjon300ci
coils
