7.3 Not running good
Old Nov 22, 2007 | 11:41 AM
WH90's Avatar
WH90
Unhappy 7.3 Not running good
Sup everyone, i gotta 2001 f250 7.3 and the motor shakes at idle and sounds really loud when its warming up, i let it warm up to the normal lines before i drive it, it doesnt have much power anymore and there is a huge grease spot on the radiator possibly a bad intercooler maybe, i hooked up the IDS system and it has no codes and it passed the cylinder contrubution test the only codes i get it OTC fuel sender, i have no clue what that means either, thanks for any help.
Old Nov 22, 2007 | 11:48 AM
santacruzf250's Avatar
santacruzf250
Most ford diesels are loud when they're cold.
clean the EBPV tube, that might help your idle/power problem.
search about OTC fuel senders if no one else comes with info.
Good luck!
Old Nov 22, 2007 | 12:22 PM
WH90's Avatar
WH90
Aight ill do that, what and where is the EPBV tube at?
