1978 - 1996 Big Bronco
Dead Bronco
Old Nov 22, 2007 | 11:40 AM
BadAssBillyBronco's Avatar
BadAssBillyBronco
Dead Bronco
i have an 89 ford bronco fullsize with the 351 it recently died and not sure what to do... i left my house drove maybe half a mile and started to die sounded like i was running out of gas but i had a full tank then just died. it turns over a few times then sounds like its cranking hard then stops.
Old Nov 22, 2007 | 12:27 PM
blue beast's Avatar
blue beast
Pull codes and see what you get. Are you getting spark? fuel? When was the last time
it was tuned up? Have you ever replaced the tfi module?
Old Nov 22, 2007 | 12:40 PM
Mr. M's Avatar
Mr. M
First of all. Pull codes! check here for details www.fordfuelinjection.com
1. Check fuel pressure.
2. Check fuel pump relay for corrosion.
3. Replace TFI module (cheap pick and pull part). On 1989 versions the TFI was close to the manifold and takes on a good deal of heat. These were known to crap out. Later models mounted on the drivers side fender well.
If you're truck ran fine before, it will be something stupid that slowed her down.
Good Luck,
Mike
Old Nov 22, 2007 | 12:54 PM
BadAssBillyBronco
earlier that day while i was driving on the highway it did the same thing but didint totaly die just cut out for a couple seconds...
Old Nov 22, 2007 | 01:01 PM
BadAssBillyBronco
also how do i get the codes? i saw a bunch of other codes starting with (p01111 example). i rented a tool from checker auto that gave me a couple dtc codes DTC :84 with no explanation, DTC :34 and said something about a egr control fault ex. v8 models. and defective egr pressuge transender sensor, evap control system fault / voltage higher limit also the tool was saying my engine was a 6cylinder.
Old Nov 22, 2007 | 01:04 PM
BadAssBillyBronco
i replaced the fuel pump and filter less then 6 months ago.
Old Nov 22, 2007 | 03:54 PM
Mr. M's Avatar
Mr. M
Originally Posted by BadAssBillyBronco
also how do i get the codes? i saw a bunch of other codes starting with (p01111 example). .
Old Nov 22, 2007 | 07:11 PM
TimmyAbrams's Avatar
TimmyAbrams
codes are what allows us to troubleshoot over the internet without seeing and hearing your vehicle personally.
Please follow Mr. M's advice, and make sure that the KOER tests are done on a warm engine; otherwise the codes are useless.
Once you get the codes, post them here or use the search button.
Old Nov 23, 2007 | 08:56 AM
BadAssBillyBronco
the tool i reneted said make sure engine is warm but my bronco wont start...
Old Nov 23, 2007 | 11:05 AM
TimmyAbrams
sorry...
pull the codes that you have---
KOEO (Key on, engine off)
It will give you active codes and then codes in memory. Post both and we can go from there.
Old Nov 23, 2007 | 04:54 PM
wildjon300ci's Avatar
wildjon300ci
Willing to bet the TFI module died if it was running fine, then just died. Happened like that to me on my old truck, die, sit for a bit and start right up like nothing happened. Tested TFI and it was good, the next day it died completely and tested bad. Go figure...
Old Nov 26, 2007 | 12:53 PM
BadAssBillyBronco
replaced the TFI and still nothing then codes i got were DTC :84 and DTC :34 but the tool i rented from checker auto said my truck was a 6 cyl...
Old Nov 27, 2007 | 09:39 AM
blue beast's Avatar
blue beast
How is your battery charge state? If it is real low it can cause some problems.
When you hit the shrader valve on the fuel rail what do you get when it has
sat overnight? How about when you turn the key to run but do not start it?
Get the actual numbers off the computer it should be a sticker right next to
the connector. What is the general conditions of the wiring and connectors
Check the big connectors on the drivers side fender open them up and check
for corrosion, Get the Deoxit booster pen from radio shack it is one of the
best contact cleaners I have used and it supposedly improves the conductivity
It lasts a long time unlike spray cleaners which get everywhere. Have you done
the wiggle test with the code reader yet, Jiggle the wires, pull the connectors
a bit, smack the fenders. Check your fusible links sometimes they can look okay
but be burnt or even corroded with no outward signs!!
Old Nov 27, 2007 | 11:23 AM
andym's Avatar
andym
If you're going to use a tool to pull the codes that none of us have, you are probably on your own with this problem. If you're going to pull them using the method that 90% of the members here use, we can help you a lot more.
I'm sure that no one here has any idea why the cheap POS scanner from the cheap chinese parts store is saying your truck is a 6 cylinder.
Old Nov 29, 2007 | 01:16 PM
toolman's Avatar
toolman
I would chalk that up to User Error. The code reader doesn't generate the tests, reports signal pulses from the ECU. Go here http://www.fordfuelinjection.com/?p=13 and print out this section, then get an automotive test light and a length of wire if you haven't got em, and re-run the KOEO tests for current faults and stored codes. Pay particular attention to the section about terminating the test so you don't accidentally clear the stored error codes.
-Scott Jones, Spokane, Wa.
Blue '86 EB Bronco
A whole mess of Merkur Scorpios
