Sponsored by: Kumho
brake drag
Old Nov 21, 2007 | 03:30 PM
G Money's Avatar
G Money
Question brake drag
Hi guys,
I've come here for some ideas in the past so I just decided to join. I just got my F-350 4x4 this summer and now there's a problem. When I jack up my front end and spin the tires they aren't spinning free at all, they stop almost the instant you stop pushing. I also just replaced one frozen caliper the other day and now that brake is dragging harder than the others. Could there be a clog somewhere in the brake lines that isn't allowing the pressure to be released? I'm a rookie at this stuff, just looking for ideas as to what has happened to other people. Thanks
Old Nov 21, 2007 | 06:46 PM
fred_79f250's Avatar
fred_79f250
Completely different truck, but on my '79 F250 when once replaced the master cylinder, suddenly I had the same problem. In fact, as I drove, the brakes would slowly tighten down. Turned out to be a faulty replacement unit I had installed. A leak somewhere in the hydraulic portion of the unit was allowing the booster to slowly pump up the brake line pressure. Replaced the unit, fixed it.
Old Nov 23, 2007 | 11:43 AM
abealex's Avatar
abealex
I had the exact problem, although it was on my Dodge 2500. After replacing the master cylinder, both front calipers, both rotors, and both front hubs, I still had excessive drag. It turned out to be clogged hoses (the ones from the frame to the caliper). About $15 a piece from Autozone. Hope this helps.
Old Nov 23, 2007 | 06:31 PM
G Money's Avatar
G Money
Thanks abealex, that's what I am leaning towards also, because just this afternoon I took apart the rear calipers, wirebrushed them and lubed them up and they're still getting really warm just driving around town.
Thanks again
