It also keeps the seals alive in the system so the coolant doesn't leak out from not using it all winter. To me that's more important than it helping defrost the windows faster!
That's true dan...but it wouldn't need to cycle within 5 minutes to lubricate the seals.....the amount of pressure within the lines should take care of the seals in one or two fell swoops...Later
That's a possibility too.....the more blowing in the more air that needs to flow through that dryer...makes sense.....I'd say the 5 minute cycles are good.......Later
