Is there a drain plug on the HPOP. I want to drain the HPOP because I got coolant in my oil, for those of you who have not read my previous thread. If there is nothing other than the small plug at the top, what is the best way to get it out. I took some out with a medicine dropper but i will be here until 2010 doing that.
If you have a small wet dry vac you could attach a small piece of pipe to the hose and vac it out. I use a turkey baster to get coolant out of the reservoir on the radiator to test it works well and you will get more out than with a medicine dropper. As far as the rails still looking.
im not quite sure how much coolant were talking to tell you the truth...enough i can tell its in the oil but not enough to make it a milkshake or make it green, just barely tinted green so that i can see it
thanks for your help tracy let me konw what you find, i couldnt find anything helpful in the search
