fuel tank differences
Old Nov 21, 2007 | 09:18 AM
frank313's Avatar
frank313
does anybody know if a front gas tank off a 1989 ford truck will work on a 1990 ford truck? thanks
Old Nov 21, 2007 | 09:29 AM
Straight Six's Avatar
Straight Six
yes, it will deffinatley work.
Old Nov 21, 2007 | 11:12 AM
ford_boy_1996's Avatar
ford_boy_1996
It will work as long as they are the same size some are short and some are long. It makes a diff on how many gal tank you have
Old Nov 22, 2007 | 12:24 PM
lostin90s's Avatar
lostin90s
there r differences between the 89 and 90. According to all my part books. Its basically the size of fuel pump openings in tank . There is a 87-96 16 gal that has a 3 5/8 " gauge hole so you may be in luck if you have a short wheel base truck 16 gal tank.
But in 90 ish they switched to high volume systems. Hey if pump fit use it. Good luck
Old Nov 22, 2007 | 12:36 PM
lostin90s's Avatar
lostin90s
Welcome To FTE Allot of great guys here.
Old Nov 22, 2007 | 01:02 PM
oldproudvet's Avatar
oldproudvet
The openings are the same, the lock key/tab whatever, that locates the pump so that the pickup and fuel gauge sender are aimed right are in a different location. I recently bought 2 steel tanks for my 89 (which came with high volume pumps, contrary to what most say) and I had to cut a new locater so that pump would orient right in the tank. No big deal
