inline 6 300 efi rear main
Old Jan 2, 2002 | 09:10 PM
jthomps3's Avatar
jthomps3
Post inline 6 300 efi rear main
MY 1987 150 WITH THE 4.9 EFI HAS A REAR MAIN LEAK IT LEAKS ABOUT A QUART EVERY TWO DAYS=1 QUART PER 20 MILES! HAS ANYONE EVER REPLACED A REAR MAIN ON ONE WITH THE MANUAL 4 SPEED ANY SUGGESTIONS. CAN I GET IT BY DROPPING THE PAN BECAUSE 6 MONTHS AGO I JUST PUT IN A NEW PAN AND GASKET AND IT WAS A PIECE OF CAKE. ALSO ANY SUGGESTIONS ON FIXING THE (RELAY SOCKET) LOCATED ON THE LEFT SIDE FENDER WITH THE FUEL PUMPM REALY AND TWO OTHERS IN IT.ANY HELP WOULD BE MUCH APPRECIATED.
Old Jan 2, 2002 | 11:20 PM
PAUL_2's Avatar
PAUL_2
Youll have to remove the transmission & transfer case if its 4WD . The rear main seal is a one piece seal . Whats the trouble with the fuel pump relay wiring ?
Also , Please dont post using all caps . Thanks
Old Jan 3, 2002 | 02:14 PM
jthomps3's Avatar
jthomps3
The fuel pump relay wiring is rusted and most of the wires are not making contact can i just re-solder them or can i get a whole new socket?
Old Jan 3, 2002 | 11:01 PM
PAUL_2's Avatar
PAUL_2
Check with Ford Parts , there may be a splice kit deal that you can install .
Old Jan 4, 2002 | 11:33 AM
deltafordman's Avatar
deltafordman
Yeah you have to remove the trans to change that seal. Its not bad though. And you can get a new pigtail for the relay, make sure you solder the connections please. Butsplices will not work trust me, if you want to keep it from corroding again use some dielectric grease on the backs of the terminals and make sure that you put the relay back in the holder for it. Water will get into the relay and not only corrode the terminals but fill the relay with water. I have taken them off and shaken alot of water out of em....CAL
Old Mar 14, 2002 | 10:25 PM
jthomps3's Avatar
jthomps3
Thanks for the advice that rear main was not bad at all. And $70 dollars later for 2 sockets with relays the trucks runs great thanks.
Old Mar 15, 2002 | 09:00 AM
GammaDriver's Avatar
GammaDriver
quakerj
Jan 5, 2014 11:28 AM
dyoungen
Jun 3, 2013 05:15 PM
Maverick1978
Jul 25, 2012 12:16 AM
H1449-6
Aug 19, 2008 02:53 PM
ford-man
16
Nov 14, 2007 09:23 PM
