Welcome to the site, you will find it full of information.
Go to the home page and type the number in the search engine and you will get more info than you could ever want. But basically it is a pleated paper filter that replaces the stock filter and box. I personally run a K&N cold air kit that is a subject of much discussion on here but I have none of the problems people associate with the K&N. I guess you have to be smarter than the filter, any filter system will give you problems if it is not maintained and installed correctly.
With the K&N dirt passes thru the filter, nomatter how it is maintained. Someone has a link showing the tests. If you actually "look" at the tests, you may change your mind. I did. Inspect your intake tube for dust. I live on a dirt road, theres dust in my tube and its not from lack of maintanence or installing a drop in incorrectly.
This picture should explain it.
The filter is NAPA part number 6637. You have to remove the air filter housing to get it to fit. It does a MUCH better job of filtering than the stock Ford air box.
Exactly! It doesn't take a brain surgeon to Properly maintain a filter and there is no black magic. K&N flows dirt, plain and simple. I've replaced two 4-wheeler motors because of K&Ns, I have seen the tale-tale trail of dirt into the carb with PROPERLY maintained K&Ns. I guess you have to figure out if your motor is worth the risk.
It looks like you are just clamped right on the filter w/o exhaust tubing, has that held on for you?
I'm also curious, I was thinking about putting the filter gauge in the exhaust tubing between the filter and intake tube, will this work?
I would put it here.
And yes I did clamp the rubber tube to the filter.
Remove the boot from the engine. COMPLETELY degrease the clamping area that goes onto the filter. Use whatever means necessary to get it down to squeaky rubber. Do the same for the flange on the air filter.
Put your arm down inside the boot and use both hands to install the boot to the filter and clamp it down. Then install the whole assembly back onto the engine.
Rugermack, I have the AIS Ford HD air filter system now.
The only reason that I removed the 6637 and put that on instead is because the noise coming out of the intake was driving me crazy and I wanted to quiet things down a little. My truck is noisier than average inside the cab of the truck.
Sorry, I thought you had a 6637 installed. I don't realy like all the extra noise either. That would be my only complaint about the 6637 mod. This weekend I'm going to see if I can do a little insulation or something to help it out (noise).
that is the temp sensor right? not the filter minder thing? do most zip tie that temp sensor out of the way, as well as the filter minder? any chances a code can be thrown by not having the filter minder or sensor hooked up?
kwik, you need one of those fancy covers from f250 for that 6637.
I thought the principle of a pleated filter is that the multiple pleats increases the total surface area that's exposed to the air flow, so as to flow more air across more area, and filter dirt better with less restriction. It seems to me that any type of cover tends to block the action of the pleats, and limits the surface area to just the outer area of the cylinder. Besides, I thought an air filter is supposed to get dirty, that's its mission in life!
Ernest, it is supposed to get dirty... teh cover just keeps out the grossly large stuf like pieces of leaves, etc. It also helped the bird that came through my zoodad keep from getting its beak or claws tangled in the expanded metal surface on ym filter and potentailly tearing a hole in the paper. As for air flow restriction, I have not been able to tell any difference in mileage or SOTP feel or pedal response when I have run it with and without the cover.
I guess you could get a really heavy duty thick canvas that would tighten it down a bit, but that wasn't my goal or observation with the ones I'm making.
