Ignition
Old Nov 20, 2007 | 05:55 PM
387designs's Avatar
387designs
Ignition
I just finished replacing the cap and rotor, after rebuilding my distributor(TFI) according to how to rebuild a ford small block, including a new modual thing, electronics on distributor. I plan on buying new plugs and wires, and I have a blaster 2, but it is a female plug. When I buy plugs can I buy one that is male on one end? Is it worth it to put the MSD coil in? Also what brand of plugs and plug wires would everyone suggest?
It's an 85 f150 300cid
Old Nov 21, 2007 | 05:49 AM
Ranger GT2's Avatar
Ranger GT2
You may want to post this question in the electrical forum. As far as the plugs go just the normal stock plug does just fine.
Old Nov 21, 2007 | 03:24 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
We offer our Live Wires with off-the-shelf part numbers OR you can order them from us and have us build each wire to the exact length you want for each cylinder. Also with the specified boot angles.
http://www.performancedistributors.com/livewire.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Nov 22, 2007 | 01:21 PM
387designs's Avatar
387designs
alright, but an oem wire would not work with the msd blaster
Old Nov 23, 2007 | 08:50 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
You're talking about the wire between the coil and dizzy, right? There should be a wire that will work in the set, just check before you buy. Otherwise, you can order coil wires with different ends from Summit, etc.
