differences in car and truck flathead?
Old Nov 20, 2007 | 01:51 PM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
Hi, all...
Posted in flathead forum, but not much action there...figure this would be the place to get answers!
Hopefully someone here knows. I have a chance to get a 239 out of a car. I know the tranny is different, bell housing, etc, but if I use my flywheel, etc, will the car flattie work?
Thanks,
R
Old Nov 20, 2007 | 02:07 PM
merten's Avatar
merten
Hi Roger,
The short answer is yes. What year is the car engine?
Old Nov 20, 2007 | 02:08 PM
jpb222's Avatar
jpb222
You will also want to use the truck water pumps, and pulleys.
the oil pan, draft tube adn a few other odds and ends are also different but don't make much diference.
Old Nov 20, 2007 | 02:19 PM
rcav8or's Avatar
rcav8or
I believe it's a '49. I can get it for about $1200. It has been totally rebuilt, new valves instead of ground, lifters, etc. I will have to use my water pumps, and I have the oil pan off my motor.
I'm just looking at this as a way to hurry-up getting my truck on the road, and the price is very good, from what I've seen.
Oh yeah, what's a draft tube??
R
Old Nov 20, 2007 | 02:29 PM
rcav8or's Avatar
rcav8or
Couple of pictures...
Old Nov 20, 2007 | 03:13 PM
F6Guy's Avatar
F6Guy
you will also need truck exauhst manifolds, the draft tube is that black pipe at the front of the intake manifold. Also I dropped the ball, do you still want that VIN plate?
Old Nov 20, 2007 | 03:17 PM
rcav8or's Avatar
rcav8or
Yup, could sure use it...
I thought that's what the draft tube was, wasn't sure.
I already have the truck manifolds, and my exhaust is pretty decent, at least a good start.
R
Old Nov 20, 2007 | 04:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1
'49 looks right, it has studs not bolts. The driver's head gasket appears to be leaking (or was in the past). Is he running the engine with that set up?? I'd be worried about that 2x4 popping out!
There's a little more to using a car engine than you'd think (mine has a car engine). The truck water pumps have the wide belt pulleys on them, so you have to change either the pulleys on the pumps to narrow, or the crank sheave to wide. Also the generator needs a wide sheave, that is also spaced differently I think. I chose to change the pulleys on the pumps, but I'd have to do it again anytime I change pumps and it's easy to bend the pulleys taking them off and on. If I had to do it again, I'd probably change the crank sheave to wide.
Shuck the exhaust and buy a set of Red's headers, you won't regret it!
PS -- you can use the car oil pan, I am. It leaks less (no clean-out gasket).
Old Nov 20, 2007 | 04:46 PM
rcav8or's Avatar
rcav8or
actually, the leak was from the hose, and left too long. It's not from the head gasket.
As for headers, I have the stock steering, and I've heard all the headers have a clearance issue.
I have my old engine, so pulley's shouldn't be much of a problem. My old engine block isn't cracked, so I could rebuild it, but I'm just thinking this is a way, to get the truck on the road, quicker.
R
Old Nov 20, 2007 | 04:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Red's is one of the few that makes F-1 specific headers, no issues. Worth buying his "extensions" too, they get you back to near the rear of the trans from his headers. Slap on a set of Smithys and you can drive it!
$1200 isn't a bad price, IMO. Do you know what it's bored, what the crank was turned to? Did he use Chevy valves? (common mod)
Old Nov 20, 2007 | 05:08 PM
rcav8or's Avatar
rcav8or
I know it's bored .040. Not sure of the crank, or whether they are Chev valves, or stock.
R
Old Nov 20, 2007 | 08:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Compare to this local deal in Albuq.:
http://albuquerque.craigslist.org/pts/485065402.html
How can you go wrong?
Old Nov 20, 2007 | 09:03 PM
rcav8or's Avatar
rcav8or
Ross - yeah, seemed to me to be the right price! The gent has several flatties sitting around, as well as a bunch of cars. He has another one that smokes a bit.
Once in a while, I gets lucky. Now, just have to come up with the $$$'s. It's been a rough year, health-wise around here - I had a heart attack in Feb, wife had knee replacement, was down for 8 weeks, then I broke my ankle, I was down for 5, my daughter had shoulder surgery. Plus, just got a little cut on my hand, got infected, and my hand looks like a catcher's mitt!
So, I'm due for some GOOD news, for a change!!
R
Old Nov 21, 2007 | 06:45 AM
needhelp49's Avatar
needhelp49
dang i guess you are due i had a cold once i mean other then that almost dieing thing and spending 10 days in hospital
Old Nov 23, 2007 | 08:32 PM
rcav8or's Avatar
rcav8or
Ross - crank and rods are .010...believe stock valves, but new, not ground. Also rods blueprinted.
(edit - the flattie on Craigs is gone!!)
Mazda stole it from Ford...vrooom, vrooom, vrooooom!!!
R
