You might check into Goodyear A/TS's I liked the all around nature of the tire. I currently am running BFG A/Ts, which I like the best in the snow and mild dirt duties -- they're a little noisier than the Goodyears and aren't as good in the mud either. If comfort isn't a concern, I'd stick with E rated tires, since you do use your truck as a truck and the stock size for fuel economy...
I haven't tried the Toyo A/Ts, but have only heard good things about them -- maybe one of the folks running them will chime in here...
I've given up trying to find all-season tires... I run dedicated snow tires in the winter (Cooper Discoverer M+S). In the Spring, Summer and Fall I run the stock BFG Rugged Trail. I had the same strategy with my previous PSD and with our SUV's.
If I was forced to choose 1 set of tires for all seasons it probably would be the Bridgestone Dueler A/T Revo, BFG A/T's, Toyo A/T or Cooper Discoverer ATR. The Goodyear ATS that Dan mentioned could also be a good choice
