Sponsored by: Innova
amp problems please help
Old Nov 20, 2007 | 11:24 AM
kenny123's Avatar
kenny123
Smile amp problems please help
just got a new kicker 1500.1 mono block amplifer.
i went to 2 different places that install systems and for some reason no 1 can tell me why my amp light stays on after i turn off my car.
i think it somthing with the remote wire but idk can any 1 help me out.
thanks
Old Nov 20, 2007 | 11:27 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from GC.
Old Nov 20, 2007 | 05:00 PM
black04lariat's Avatar
black04lariat
Make sure your remote wire is not hooked up to a 12v constant source. It needs to be hooked up to a 12v switched wire (turns on and off with the key). And be sure to never go back to those install shops.
Old Nov 21, 2007 | 10:14 AM
CobraXP's Avatar
CobraXP
As blacklariat said, test the wire you are using for your remote wire. Disconnect it from the amp and use a test light. With the key off, if the wire has power, you have teh wrong wire coming back. It should only light up the test light when the car is on or if the radio is on (depends on where your wire is coming from).
