CD player help?
Old Nov 20, 2007 | 07:50 AM
Fair 96's Avatar
Fair 96
CD player help?
Got a 96 F150 302 auto 2WD . When I press the brake my CD player cuts out. I looked under by brake pedal thinking maybe a wire was loose or something and it looks all clear. Any tips appreciated.
Old Nov 20, 2007 | 08:09 AM
chrono4's Avatar
chrono4
It cuts out as in the entire player shuts off? Where do you have the cd player grounded through, the harness or did you just put the ground to the dash frame or the like?
Old Nov 20, 2007 | 08:17 AM
Fair 96's Avatar
Fair 96
Yes it cuts out then when I release the brake it starts up again. (does not seem to do it when the radio is on) If I barely touch the brake it is ok. I think it was grounded at the frame. It just started doing this I have had it in the truck for 4 years without a problem till this morning.
Old Nov 20, 2007 | 08:21 AM
chrono4's Avatar
chrono4
Cd players tend to cut on and off when voltage gets too low (like a dying battery) I would start by just pulling the cd player and making sure all the connetions are tight. If that doenst fix it then put a volt meter on the power wires and hit the brakes and see if it drops. If it does, then you have a problem further upstream.
Old Nov 20, 2007 | 08:32 AM
Fair 96's Avatar
Fair 96
Thanks alot I will try that.
