starting problem question
Old Nov 20, 2007 | 07:34 AM
ramarado's Avatar
ramarado
73 model automatic, won't start with the key. Starts fine at solenoid (new), so that leads me to the neutral switch or the key switch. Does anyone know which of the wires on the lead that looks like a trailer plug going to the Neutral switch should be "hot" when the key is turned to all the way to the right in the 'START" position?
Old Nov 20, 2007 | 12:24 PM
Mil1ion's Avatar
Mil1ion
The black/red stripe wire is the Neutral start circuit.
Jumping those 2 wires will allow the starter to crank.
Check your adjustment
Old Nov 21, 2007 | 01:48 PM
trinogt's Avatar
trinogt
Another thing that got me once was a poor engine to chassis ground. Once I fixed that, easy starts and my gauges started working properly again.
