3-speed questions
Old Feb 28, 2002 | 01:39 AM
indy10's Avatar
indy10
3-speed questions
[updated:LAST EDITED ON 28-Feb-02 AT 03:16 AM (EST)]I have a 300-6 with a 3-speed column shifter, and a 3.00 9'rear. I was wondering if anyone with a 3-speed has had any problems squealing the tires? Also, is there a way to make the tranny a little more beefier or more heavy duty? as in rebuilds?
I'm asking because last Sunday, I was driving in town and hit a red light. I live in Alaska, and saw the first blacktop in months so I decided to drop the clutch and slammed the gas. When I did the clutch pedal suddenly hit the floor and I was stuck in first gear. What happened was the equalizer bar (I think that's what it is) came off the to plastic ***** it rolls on to push the throw-out bearing in. I had to unbolt the bracket off the frame to get the bar back on and luckily found the adjuster bolt for the clutch pedal. Me or anyone else has no idea how this happened. The only thing I can think of is that the motor shifted over enough (1.5"! at least) to throw the bar off. Also does anyone know where i can get some new motor mounts for the 300-6, because when I went to get some new ones they were all to big. And that was from a couple different parts stores. Has anyone else had this problem with motor mounts being the wrong size?
Old Feb 28, 2002 | 11:05 PM
wtroger's Avatar
wtroger
3-speed questions
You are just plain lucky that the engine didn't go through radiator. The clutch linkage fell off because the engine torqued up becasue the motor mounts are bad. What year are you working on probably can give you Ford part number.
Old Mar 1, 2002 | 02:18 AM
indy10's Avatar
indy10
3-speed questions
it's a 78 f-150 custom
Old Mar 21, 2002 | 11:26 AM
custom_truker's Avatar
custom_truker
Post 3-speed questions
I am new at this working on trucks on thing and I have a 78 f100 custom with a 3 speed column shifter. Anyone out there know if it is possible to switch that to a floor shifter? That column is a nightmare to shift very fast and it takes forever to go from one gear to the next.
Old Mar 21, 2002 | 08:40 PM
Njbmx's Avatar
Njbmx
i have an '82 f-150 w/ a 300ci. i6 and 3sp. i have a hurst indy shifter. its a conversion kit from hurst that converts the column linkage to the floor shifter. its kinda tricky to hook up. but its a hell of alot better then the 3 on the tree setup.
Old Mar 21, 2002 | 09:43 PM
carlos57's Avatar
carlos57
3-speed questions
I did the same thing with a '67 Ford F100. Put a Hurst shifter on the floor when the column broke. Worked great. Used it to tow 2 loaded grain wagons to the elevator. Never had a problem towing anything with it. Wasn't made for doing burnouts though. Got great traction and when popping the clutch in first would damn near bring the front tires off the ground. I had yanked the 240 and put in a 300 using the intake and exhaust from the 240 with the 1 barrel carb. 18mpg and ran fine. Moog Cargo Coils (variable rate coil springs) on the front stopped the wander and tire wear.
Carlos
Old Mar 21, 2002 | 09:52 PM
carlos57's Avatar
carlos57
3-speed questions
Old Apr 24, 2011 | 09:53 AM
popsand3's Avatar
popsand3
I have a 85 f-150 with a 3.03 column shifter would like to know if there is a rebuild kit out there for the linkage yoke. Would really like to keep the column shifter it is an occassion only vehicle
yeahoner
May 14, 2022 09:10 PM
Sous
277
Jul 12, 2017 08:12 AM
Bubba Jones
May 4, 2016 02:11 AM
yeahoner
Jun 16, 2015 07:13 PM
Econo4spd
Jun 24, 2014 01:45 PM
