Sponsored by: Auxito
door ajar light
Old Apr 5, 2002 | 06:22 PM
BEEV97's Avatar
BEEV97
door ajar light
my door ajar light stays on its makeing me very angry how do i get rid of it.
Old Apr 5, 2002 | 09:19 PM
nitro94's Avatar
nitro94
door ajar light
The switch is mounted in the door on the latch. It is usually the drivers door that causes the problem. Try a brake parts cleaner or electrical parts cleaner and spray it into the latch from all angles. Lots of it. Work the door latch several times and spray more. It will usually work. If all else fails remove door panel for axcess.
Old Apr 6, 2002 | 05:51 PM
larrs1's Avatar
larrs1
door ajar light
You didn't mention if you had a extended cab or not but if you do it might be one of the back doors I have to slam the of it to keep my light off on my 2001 extended cab f-150 also my girlfriend has an xtra cab ranger with the same prob.
Old Apr 8, 2002 | 10:50 AM
BEEV97's Avatar
BEEV97
door ajar light
hey pal thanks for the input it got fixed you the man brother
Old Apr 8, 2002 | 02:30 PM
Curtis360's Avatar
Curtis360
door ajar light
Yeah thanks, my 98 Flareside was doing the same thing. It took two squirts of WD-40 to get it to work perfectly! Thanks!
Old Apr 8, 2002 | 03:22 PM
rt2jesus's Avatar
rt2jesus
door ajar light
