Knock, Knock
Knock, Knock
This is no joke, but my 1988 351 engine knocks when I first start it up cold for about 5-8 seconds and then quites down.
It makes no noise when started warm.
I am running Castrol 10W-40 "High Mileage" oil right now and purchased a bottle of Slick 50, does anyone have any better ideas than the Slick 50 ??
I assume this noise are the Piston rods and is this normal noise and anything to be worried about ??
Is it a "bang" sort of knock like a hammer smacking the side of the engine, or is it more of a "tink" kind of knock, like someone using a large screwdriver to smack it?
Since it goes away after a few seconds and doesn't do it warm, I would think away from the pistons and more along the lines of a lifter tapping, or possibly a rocker arm. There are other options, but those are the most common.
I used frams when I first bought my 82 F100. The engine would tick loudly for a few seconds after startup.
According to quite a few people fram filters are junk, the small check valves can get stuck open allowing oil to flow down from the top end of the engine when its shut off, resulting in a dry top end when you start the engine the next morning.
I switched to a motorcraft filter and all was fine, this was on a 300 I6 with 220,000 miles.
on
The fram filters found at many parts houses have a very poor check valve assembly that will allow all the oil to drain from the motor overnight. On startup it will take some time for the pump to prime all the lifters again. Simply swapping to a motorcraft FL1A will eliminate these colt start rattles. I have seen this first hand on my trucks, and on our Subaru that I recently did an oil change on. I used a Fram filter because it was all I could find at the time, and now it rattles on cold starts for a few seconds.. something it doesn't do with the Subaru filters.
