Need HELP with lower door hinge
Old Nov 19, 2007 | 12:13 PM
BlueSpark's Avatar
BlueSpark
Why is it always the jobs that should be easy turn into the nightmares? I have the door hanging from the garage door rails, it's unbolted and i'm removing the lower hinge from the body. The last bolt comes out and I hear the dreaded sound of metal falling. The backing plate that the bolts thread into fell inside the body somewhere and I can't seem to find it.
Does anyone have any suggestions to help me out?
Thanks!
Chad
Old Nov 19, 2007 | 12:43 PM
89frankenford's Avatar
89frankenford
take the kick panel out and stick a magnet down there. you should be able to retrieve it. same thing happened to me a few weeks back when i replaced my lower door hinges.
Old Nov 19, 2007 | 01:34 PM
BlueSpark's Avatar
BlueSpark
THANKS!!!! I got it.
Chad
Old Nov 19, 2007 | 05:07 PM
lostin90s's Avatar
lostin90s
Glad it work . I use the garage door rail all time. To replace the hinges. I like your way of thinking.
Old Nov 19, 2007 | 06:14 PM
BlueSpark's Avatar
BlueSpark
Yea, they come in handy for all sorts of things. My favorite is as a makeshift paint booth. I just throw some visquine over them and put a fan under the door to blow everything out. It works great for small jobs that do not have to be "perfect".
Chad
Old Nov 19, 2007 | 07:59 PM
Linemo's Avatar
Linemo
is this a common problem when changing hinges or just an isolated incident i have bought a new upper and lower for my 1996 F-250 drivers side door they are very worn was debating to replace myself or let a body shop do it what are you guys thoughts
