Bad Battery!!!!
Old Nov 19, 2007 | 08:47 AM
tttario's Avatar
tttario
Thumbs down Bad Battery!!!!
Hey Fellas,
Tried to start my truck this morning and I had a dead battery. Opened up the hood and the driver's side battery + post was full of bluish green crystals. Hooked up my wife's car to the truck, but it didn't have enough power to help turn the truck over. Put my booster pack on the other battery and still nothing. Tried periodically, every 5 mins, but still nothing. Left everything plugged in for 25 mins without touching it and then she started.
I know this battery is finished and I will be replacing. Should I replace the other battery as it as been taking added strain by compensating for the other? I don't think that these batteries are on warrenty as it is an 05 and has 116,000 km (70,000 mi) on it. Are both batteries the same model?
Trevor
Old Nov 19, 2007 | 09:27 AM
Storm's Avatar
Storm
Both are the same.. and honestly I always learned to replace them in pairs.. But you could probably get away with just changing that 1 until later.. Heheh you probably should replace your wife's too, I'm sure her car is swearing you up and down for the workout you gave it.. LOL
Old Nov 19, 2007 | 10:23 AM
69cj's Avatar
69cj
Always replace the batteries in pairs or the old one will drag down the new one. It's been proven.
Old Nov 19, 2007 | 10:25 AM
tttario's Avatar
tttario
OEM or upgrade to gel? Are the gels the same physical size?
Old Nov 19, 2007 | 10:28 AM
Storm's Avatar
Storm
Seriously.. If you got the cash, go get Optima's.. They are by far the BEST batteries for our truck.. They aren't cheap, however you won't die out as quick as standard OEM batteries go..
Old Nov 19, 2007 | 10:30 AM
MisterCMK's Avatar
MisterCMK
ALWAYS replace them in pairs. I've heard of many Optimas biting the dust prematurely so I would probably stay away from them. I've got a Werker from Batteries Plus in my Explorer and it is doing great. I had a sears battery in my Mustang and it was 6 or 7 years old when I replaced it.
Old Nov 19, 2007 | 10:32 AM
MisterCMK's Avatar
MisterCMK
BTW, I see you are i northern Ontario. Cold weather is very had on batteries so I think that 2 years isn't all that bad out of a battery. You might want to think about getting battery warmer blankets or something like that for them when it gets really cold.
Old Nov 19, 2007 | 10:40 AM
69cj's Avatar
69cj
Optima's might be good? But they don't last any longer and aren't warranteed any better than standard batteries. For the same money you could get two sets of lead acid batteries and a twelve pack with the change.
Old Nov 19, 2007 | 11:08 AM
tttario's Avatar
tttario
MMMMMMMM! Twelve pack! You sold me. I think I will stick to the OEM's and replace both. Right now I have a thin insulated black blanket around my battery. It does not give off heat or anything. Is this a battery blanket or is there something you can get to give off heat? It gets pretty cold up here especially at night (-35-40). What are other upgrades I would benefit from for extreme cold like this.
Oh, thanks alot for the help on this.
Old Nov 19, 2007 | 11:15 AM
69cj's Avatar
69cj
I can't help you with the blanket thing. Here in S. Cal. we think 50 degrees f. is cold!
Old Nov 19, 2007 | 11:35 AM
ripnlips's Avatar
ripnlips
I have the same thin black blanket on my 05 batteries. Does anyone know what it does?
Old Nov 19, 2007 | 11:40 AM
69cj's Avatar
69cj
I think they are to protect the batteries from excessive underhood temperatures. Mainly heat.
Old Nov 19, 2007 | 12:29 PM
MisterCMK's Avatar
MisterCMK
There ya go. I sure hope you are plugging your truck in when it gets that cold.
http://www.jcwhitney.com/autoparts/P...000917/c-10101
Old Nov 19, 2007 | 12:37 PM
eharman's Avatar
eharman
I noticed that your truck is a 05. How many miles do you have on your truck? I have a 03 with 62,000+ miles with the original batteries. It may be getting time for me to replace mine?
Old Nov 19, 2007 | 12:46 PM
69cj's Avatar
69cj
I only have 15,000 on mine.
