windscreen pillar rust
Old Nov 19, 2007 | 12:23 AM
Ken Blythen's Avatar
Ken Blythen
Unhappy windscreen pillar rust
I'm in the middle of buying an 82 F-350 which is in basically excellent condition.
But for some reason it has a spot of rust, about 1.5" across, in the same place on each pillar, just below the top of the windscreen.
Both spots look as if they began from the outside (no holes) - but the fact that they are both identical & in the same spot, makes me wonder if this is a problem area.
If so, does anyone know the cause, & how much of a problem could be lurking
underneath?
Thanks
Old Nov 19, 2007 | 02:32 AM
khadma's Avatar
khadma
Carpenter Local 745
Is it at the seam line near the raingutter?
Old Nov 19, 2007 | 09:58 AM
Franklin2's Avatar
Franklin2
That's not a common rust area for these trucks. If you poked at it, would it go through?
Old Nov 19, 2007 | 10:59 AM
Ken Blythen
No, both spots are about 3" lower than the gutter, same on both sides.
They wouldn't push through yet, but are far enough on that it needs cutting out.
It looks localised but I wondered if someone had seen this before
Old Nov 19, 2007 | 09:32 PM
FFMCPres's Avatar
FFMCPres
I'm kind of curious about this, too. Mine's an 82 F250, 127K, 400/4spd, built in Cally, spent most of its life in Colorado, and has been in PA for the last 5 years. I have rust just as you describe in the same place on the passenger A pillar, but only a small spot on the driver's side. I'll have to pull the windshield to do this right (someday!) but as of now it's just an ugly, rough scab with no perforation. There's got to be more than the two of us with this issue...
KiwiFord
112
Mar 17, 2020 11:50 PM
baker51
Australia Chapter
Dec 8, 2014 09:54 PM
pjotri
Mar 4, 2013 09:14 PM
Sa-58panel
15
Jul 30, 2009 05:44 PM
54truck
Sep 21, 2008 09:11 AM
