99 oil pan leaking
Old Nov 18, 2007 | 10:26 PM
dd4's Avatar
dd4
99 oil pan leaking
So what's it take to replace the oil pan on a 99 f350 7.3?
thanks
Old Nov 18, 2007 | 10:34 PM
Tail_gunner's Avatar
Tail_gunner
thanks
A "cherry picker", engine stand, at least one buddy, 2 to 3 days and oh yea, a new oil pan and the "special sauce" sealant.
The engine must be pulled, flipped up-side down on an engine stand, old pan removed, new one installed with 24 hours sealant cure time and put the motor back in.
Old Nov 18, 2007 | 10:35 PM
1996pwrstrk's Avatar
1996pwrstrk
If you want to replace your oil pan you will have to pull the engine completely out. If you have a hole alot of members have repaired them in various ways I bet they will pipe up shortly.
Old Nov 18, 2007 | 10:44 PM
Kwikkordead's Avatar
Kwikkordead
I patched mine with a gas tank repair kit. Three years and no leaks. Here's the link to what I used.
http://www.napaonline.com/MasterPage...ank+Repair+Kit
And it that doesn't work here's the part number.
BK 7651544
Old Nov 18, 2007 | 10:49 PM
Kwikkordead
Here's another one:
http://www.napaonline.com/MasterPage...nk+Leak+Sealer
BK 7651546
Old Nov 18, 2007 | 10:58 PM
randomhero1172's Avatar
randomhero1172
Ya oil pan with this truck is about a 1000-2000 dollar repair depending on the mechanic. I did something similar to kwik and dead .. it worked GREAT! here it goes
- Drain all oil
- with wire brush (grill brush) scrap off all the nasty crap on the bottom until its pretty clean. then use a rough grit sander to make sure your oil pan is nice and rough (and clean!)
- Again, make sure the area where the hole is, is nice and clean
- i applied some starting fluid to the pan to make sure everything was nice and dry.
- I used Bondo liquid fiberglass (the stuff with the "hair" in it) and applied it in 3 layers over about 2 hours. I used a brick and morter spreader to make sure it was nice and even. I did my entire pan too, just to make sure. Let dry for about 12-24 hours before driving.
This worked great, save ALOT of money and TIME! Definitely do this
