Sponsored by: Real Truck
ABS light
Old Nov 18, 2007 | 04:49 PM
Rubidon's Avatar
Rubidon
ABS light
Is there any way to get a trouble code from the abs light.I know that if you ground a certain wire,on a 88 f-150 & bronco,the abs light would blink out a sequence and that would tell you what was wrong.I just wanted to know if this could work on a 99 SD 250?
Old Nov 18, 2007 | 06:15 PM
Rongold's Avatar
Rongold
Abs Codes
Nope, the 99 is OBD 2, and you need a scanner capable of reading 96-2003 OBD 2 codes.
RON
