Sponsored by: Real Truck
Dually Questions
Old Dec 16, 2007 | 09:19 PM
oltrucker's Avatar
oltrucker
the dually rear axle is a mch bigger one than the srw. dont use nything but synthetic gear lube in it. 90-140.
Old Dec 16, 2007 | 09:40 PM
sawboy's Avatar
sawboy
GwizRc, I just sent you an email. I love your set-up man and goota have me some details!
Old Dec 16, 2007 | 10:30 PM
GwizRC's Avatar
GwizRC
Thanks, I lifted the front with 2” Spacers and shocks. I installed dual steering stabilizers. I installed Firestone #2400 air bags in the rear. Then I had six new Super Swamper Radials (SSR’s) installed on my factory rims. The tires are 35x10.5x17 load range E and can be mounted on 7-9” wide rims. After they installed the tires, I took a picture of the duals and the spacing between them. I immediately installed a 2” spacer by Arrow to increase the gap (see gallery). I am very pleased with how everything turned out. The tires hum on the highway but not loud enough to annoy me (yet). They seem to handle pretty good.
I had to adjust my pin box on my fifth wheel to make it level again. It tows just as good as before. Braking is a little slower but still good, especially with the tow/haul mode.
I love the looks and the performance off road. I used to get close to stuck with the factory tires before, now I don't even come close to getting stuck. I live on a ranch and use the truck a lot.
Old Dec 16, 2007 | 11:54 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by lref250ld
Also I know all duallys come with 4.10s(or I think) can you put 3.73's from an f-250 or another f-350 NON dually in a Dually rear end?
I didnt/dont know for sure if the ring gear sizes are the same.
For one, No.
For two, you will experience worse fuel mileage with higher gears (numerically lower), especially when towing. Lower gears (numerically higher) will make it much easier on the engine (therefore, less gas use) to get the truck moving.
Old Dec 18, 2007 | 03:04 PM
TowTime's Avatar
TowTime
I have an 03' 7.3 with chip and get about 15-16 miles per gallon. And it is a 3.73 rear. Plenty of pulling strength and not to bad with fuel consumption. Unless I try to run over 70 and then it goes to garbage.
Old Dec 18, 2007 | 04:25 PM
redford's Avatar
redford
FTE Leadership Emeritus
That is incorrect.
Per the Owner's Manual for the '06, the Dana 80 axle requires Motorcraft SAE
75W-90 Synthetic Rear Axle Lubricant
http://www.analogstereo.com/pdf/om/f...anual_2006.pdf
Old Sep 16, 2009 | 09:59 PM
Michael Fender's Avatar
Michael Fender
Hi Sounds like I have about the same rig as you. What chip (brand) did you use? Thanks Mike.
King Ranch 350
Jun 4, 2013 07:41 PM
URDADDY
Sep 17, 2012 08:22 PM
racecarguy
Modular V10 (6.8l)
15
Mar 12, 2009 05:00 PM
Jackflack
May 16, 2004 11:32 AM
dani9678
Paint & Bodywork
Jan 21, 2004 02:11 PM
