351 heads
Old Nov 17, 2007 | 11:44 PM
smoke n tires's Avatar
smoke n tires
351 heads
how much difference will 69 windsor heads make over my mild ported e7s on my 306? ive heard alot due to valves and intake runner volume. i got a set and dont know if i should install them because im scared it would make a difference. my 306 runs great now but doesnt have the top end i need. it flatens out at 5000, even on spray. i know the e7s just cant keep up, will the 351s?
Old Nov 18, 2007 | 07:37 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
http://www.carbdford.com/tech/headflow.htm
Old Nov 18, 2007 | 08:22 AM
smoke n tires
thanx for the info. kinda disapointed to see the windsors only flow alittle more on the intake. doesnt seem to be that much more.
Old Nov 18, 2007 | 10:38 AM
Conanski's Avatar
Conanski
The windsor family heads didn't change a whole lot over the years, smaller combustion chambers and slightly larger valves in the early years, but as you see it doesn't amount to much in terms of flow. The best flow numbers I have seen for Ford heads are from a set of Thumper Performance E7's which are close to the World Products Windsor SR.
Old Nov 18, 2007 | 01:05 PM
HemiEater's Avatar
HemiEater
be surprised how much that little feels @ 6000.....
Old Nov 18, 2007 | 01:24 PM
smoke n tires
really ? thats where i need the power. i have tons of torque but no real top end. maybe ill port them and give em a shot.
Old Nov 18, 2007 | 01:36 PM
HemiEater's Avatar
HemiEater
port the E7s and use 1.94 .160 valves..... Done a few sets, not that hard to do just takes a lot of time.
whats this for your GT.....?
got a bunch of pics from my porting days if you interested.
Old Nov 18, 2007 | 08:03 PM
smoke n tires
yes, the heads are for the gt. its currently on spray but i want more top end. the e7s pull really hard but fall around 5000. i think its the compression (9.75-10-1) is to much for these heads. sure id love to see your porting pics hemieater. the e7s are ported on the exhaust side but the valves are still small.
Old Nov 18, 2007 | 11:58 PM
Mr. M's Avatar
Mr. M
As this gentleman stated... not hard, but it takes some time. Really woke up my motor with a full port job and 1.94/1.60 valve set.
Old Nov 19, 2007 | 02:31 AM
HemiEater's Avatar
HemiEater
My Porting Pics.......
Old Nov 19, 2007 | 11:20 AM
smoke n tires
they look beautiful! i think ill just spend time on the 351 heads since the valves are already bigger and they are off the car. then when im ready ill swap them over and see what happens.
Old Nov 19, 2007 | 02:02 PM
HemiEater's Avatar
HemiEater
things you should do....
have the heads magnafluexed
have the stud bosses machined for guide plates
have the studs bosses drilled and tapped for 7/16 studs
have hardened exhaust seats installed 1.60
have them use the one piece tool that cuts the seats and opens the bowls at the same time 1.94 and 1.60 3 angle valve job....works great.
have the seal bosses machined for the high performance seals
the one piece tool is the ticket...not sure what it's called but when you get the heads back all you have to do is blend the bolws....like this...
notice the intake bowl......all I had to do was blend in the guide boss....
before
after
Old Nov 19, 2007 | 04:11 PM
71dusterdan's Avatar
71dusterdan
mind if a pop off a couple of questions nearly related. gonna rebuild my 89 351 this spring. i am gonna use a performer intake and cam and i need to get my compression up over 10 to 1 for e85. please lets not debate my choice in fuel it is readily available here and a buck cheaper plus. it appears the combustion chambers in my engine are like 69.cc's, and i havent been able to find a piston that can work with that chamber and get me where i need. I was gonna buy reman heads from aerohead/ indy cylinder head( a big name in mopar circles) they just started windsor heads and all new parts stainless 1.94's and 1.60's with a 3 angle valve job can be had for $400.00. i dont believe i could have my heads done for less. it is just a hopped up work truck in need of some extra grunt. can anybody steer me to a good iron head with a smaller combustion chamber or a piston that can get me over 10-1. thanks guys. Dan
Old Nov 19, 2007 | 04:29 PM
HemiEater's Avatar
HemiEater
10to1 with e85 what is e85???
Old Nov 19, 2007 | 04:32 PM
Mr. M's Avatar
Mr. M
Ethanol- FlexFuel
