Basic welding with a torch?
The bed on my 78 is a bit loose on one end, it just needs a bit of extra support.. it's not bad at all, JB-Weld almost holds it until I do any real offroading in it.
With no experience, can I go buy some item to weld this small section of my bed with using a propane torch? It doesn't have to look good (it's on the floor of the bed, under a bed liner) and it doesn't have to be very strong.. I just know I can't buy any extra equipment at the moment, so I'm hoping there is something I can buy for a few bucks that I can melt with a propane torch..
Thanks.. and sorry for being an idiot
Learning to weld is on my super long list of things to do.
The metal will have to be pulled together or metal pop riveted in to fill gaps because, brazing has no "filling" properties. Wire brush the metal good, heat it until it turns cherry red then lay the end of the brazing rod on it while keeping the torch on it. . ...
If the metal is hot enough, the flux on the rod will melt first, then the rod will flow like water and cool hard to look like brass. Not as good as a mig or stick weld of course, but may get you by until you win the lotto. good luck.
P.S Watch out for combustibles or gas lines /leaks near the repair !!
Then if this is in a middle of a panel you may warp it due to heat.
Learning to weld is on my super long list of things to do.I'll probably get an angled piece to braze to my bed to hold it together. It's at the bottom, driver side corner below the tailgate.. the two pieces overlap each other, though I'm not sure they still will when I cut/sand down all the rusted through areas.
If I get good enough maybe I can use it to do my cab corners? we'll find out.. couple of bucks for a brazing rod, I have a ton of scrap metal to practice on.. Gonna have fun with this tomorrow.
Gonna see if I can find some brazing videos on youtube. Even with that guide (which was a TON of help) I still do better seeing it done in action first.
Work on reading the metal temp. The flux will melt just before the bronze does, so you will know when your getting close. If the thickness of the materials are the same it easer, other wise you have to concentrate on the thicker metal.
I'm thinking about all the cool things I can do now.. for example, I have a transmission cooler I custom made with two fans, been trying to think of a good location to zip tie it to the truck. It would probably take me about 3 minutes to make a custom mount now..
Would it be stupid for me to try to braze towhooks to my front bumper support? (78 F150) My old U-Joints would be perfect..
oooh, I could start some custom skid plates. Flat sheet metal or even a tube cage for the lower section of my truck, that should be easy.
I'l really excited.. I plan on spending quite a bit on fuel and rods tomorrow.
Don't get carried away with brazing, it's use is limited. I use to do a lot of silver soldering on refrigeration lines. It's slighlty lower temp than bronze.
If you really think your got your temp control down. Pickup some AL electric welding rods and use a oxy/acet torch to weld AL sheets together. There is some AL brazing rods but it's not the same. It's a lot easier with a tig torch. I want to build a custom gas tank for my 68 and haven't decided if I want to buy a TIG welder big enough for 1/4" anchor plate or use my oxy/acet torch.
My budget is extremely limited at the moment.. was going to get a tax refund loan but decided it would be better to wait, so until I get my refund I'm working on a "whatever I have left, after savings" budget.
They have a kit with Oxy/Acet at a Rural King store here for $30, it comes with the torch. Will I definitely need both to heat metal hot enough? I liked the idea of the small, single bottle of propane, it's easy to handle. Can I use a straight oxygen or acetylin bottle on my propane torch and have it burn hotter than the propane I'm using?
The bottles are both about the size of a small, handheld propane bottle. They sell straight oxygen or straight acetylene and it's dirt cheap.
Remember that you will have to have the bottles filled, those small bottles only 12" or so high will not last very long. Used mainly in plumbing and AC work. ALL acetylene bottles must be vertical. You can not lay them on the side. It contains acetone as a coupler in which the acetylene is dissolved in. The cylinder has a honeycomb substense for the acetone. If you lay it on the side acetone will damage the regulator.
