A/C delete
Old Nov 17, 2007 | 09:54 PM
DesertStorm's Avatar
DesertStorm
A/C delete
I am taking the a/c off of my 1993 4.0 ohv. Anyone know where to get a idler pulley setup to delete the compressor. Also i want to remove the evap. coil in the blower box. Any ideas how to remove without making it look like crap?
Old Nov 17, 2007 | 10:38 PM
Nick37's Avatar
Nick37
I would just unplug the compressor clutch and leave all the parts in place. If you are trying to save weight, you may be able to remove the compressor and buy a shorter serpentine belt and skip the extra ideler. On the 3.0 ranger and the taurus Ford just puts a shorter belt on non-A/C models.
The condensor is easy to remove but the evap is going to be a long job.
Old Nov 17, 2007 | 10:40 PM
5.0B2's Avatar
5.0B2
Quite regularly on Ebay - If you can find a non-A/C Explorer or ranger the engine compartment half of the Heater blower assembly should bolt in inplace of yours.
Old Nov 17, 2007 | 10:42 PM
DesertStorm
I cant remove the compressor and shorten the belt b/c the angle on the water pump to p/s pump will be wrong and the belt will rub itself. I want to get rid of all the a/c crap so i can work on the engine more easily. I want to clean up the engine bay to make it look better also.
