Heater ?
Old Nov 17, 2007 | 11:47 AM
jmtbiggin's Avatar
jmtbiggin
Heater ?
Truck is fully warmed up. Temp dialed all the way to red.Heat blows hot in defrost, floor or dash vents when moving.Stop at light or sign, and it blows cold. Any ideas
Old Nov 17, 2007 | 11:52 AM
rollerstud98's Avatar
rollerstud98
low coolant
Old Nov 17, 2007 | 02:57 PM
PupnDuck's Avatar
PupnDuck
The heater core could be partially plugged (unlikely) or the vacuum controlled heater valve could be defective.
Old Nov 17, 2007 | 05:10 PM
barnbridge's Avatar
barnbridge
My guess is vacuum leak, perhaps pump or hoses.
Old Nov 17, 2007 | 08:32 PM
moebdick's Avatar
moebdick
There's a TSB about the vacuum pumps flaking out on some trucks. Hopefully it's just a leak like barnbridge said, but if not you may need a new vacuum pump.
Old Nov 17, 2007 | 09:45 PM
jmtbiggin's Avatar
jmtbiggin
Coolant was low. Heat is good,thanks
