little technical info please
Old Nov 17, 2007 | 04:28 AM
bad_habit59's Avatar
bad_habit59
after reading some post on here about advancing the timing on my truck, I was talking to my buddy about it and he seemed to think if I did do this my low end torque would suffer. See as i am mechanical ignorant and there are some very informed people on here I thought I would ask. is this true and if so perhaps a simple explanation to enlighten the few amongst us that are behind in our mechanical theory
Old Nov 17, 2007 | 09:40 AM
DJdemon6696's Avatar
DJdemon6696
mine is at 14 BTDC* and i got no problems with it.. exept more power
Old Nov 17, 2007 | 10:14 AM
quicklook2's Avatar
quicklook2
hard to believe it doesn't ping at 14.
Old Nov 17, 2007 | 10:22 AM
Conanski's Avatar
Conanski
Your bud is wrong and the exact opposite is actually what occurs, you will see a gain in TQ. The problem people have with this probably comes from the terminology used. "Advanced" timing means the plug is fired a few degrees before the piston reaches top dead center(TDC). This means combustion actually begins before TDC, and this increases compustion pressure which increases TQ output. Advancing the timing beyond the base setting of 10degrees will further increase TQ output, but a motor will only tolerate so much additional timing before combustion chamber temperatures get too high and the mixture will start to ignite without a spark, which is known as pre-ignition, pinging, or detonation.
Old Nov 17, 2007 | 11:35 AM
DJdemon6696
i know i still dont know why :S..
when i found it it was at 7 * BTDC
when we where setting it when it reached 0* it made a loud sucking noise tru the intake and a vwery rough idle.. but no pinging...
ohh and btw where i live we only get 90 octane at the pumps maybe thats why it doesnt ping at 14 BTDC*
Old Nov 17, 2007 | 02:20 PM
lostin90s's Avatar
lostin90s
Every Ford truck I owned has a sweet spot. Where HP and MPG meet. I'd timed them (Sprout out). And take for ride and just not right. Now I just take for a trip up 5 miles hill . when starts ping. I back off and its sweet. Mine right now is at 12 DEG and is very happy . But I back off little it just lays down . Later
