56 Fuel gauge
Old Nov 16, 2007 | 11:15 PM
56efffie's Avatar
56efffie
56 Fuel gauge
I just recently pulled and cleaned my gas tank. Everything looked good no rust etc. I replaced the cork gasket for the sending unit and buttoned it back up. When I turn the key the gas gauge registers but then slowly returns to a empty reading?? Does anyone have an idea why? I'm stumped.
I guess I should also add that I have never put gas in it till now due to not knowing what was in there.
Old Nov 17, 2007 | 08:39 AM
WALFORD'S 56's Avatar
WALFORD'S 56
I think it may be a connection or a wire that runs to the gauge,that needs some attention. I also,have a gauge on 1 of my trucks that I replaced everything nd the gauge acts empty,until I move the wire......I would look at the wire leading around the door to the dash.........Bill
Old Nov 17, 2007 | 09:20 AM
56efffie's Avatar
56efffie
Thanks Bill, I will check the wires out closer, that would be better to find than to replace a gauge or sending unit.
Old Nov 17, 2007 | 05:11 PM
ghall's Avatar
ghall
Good luck with it!
Any real quick troublshooting tips on these?
mine reads full..... no matter what... until I disconnect the wire at the sender
but when i pull the sender and test with meter, it seems normal... according to published ohm readings, and seems to respond well when moved thru range of motion.
but when i reinstall and hook it up... full......
DR Smith
24
Jun 13, 2014 03:36 PM
Skipstowin
Jul 15, 2007 03:35 PM
NormH
Mar 21, 2007 11:59 AM
LEckart
Feb 20, 2004 07:40 AM
56F100
Electrical Systems/Wiring
May 19, 2001 03:03 AM
