I have a 96 powerstroke ex cab long bed. the problem is i want to put a dana 70 off a small school bus under it. I got it all to fit but the tranny started to shift funny and not work because the speed sensor in the rear dif. does any one make a kit to move that to the drive shaft or eliminate it from the system, or something like that?
That is one that I haven't come across. Try using the Forums tab at the upper left and scrolling over the boards. You can try your year of truck or you might also try this one: https://www.ford-trucks.com/forums/forum69/ See what they say.
