It should be '87-'96, btw. '86 still had the same door glass as the years before it, but they changed slightly in '87.
I believe if you were to change out your wing glass too, you could use any from '80-'96, though I don't know if the screw holes are the same from '86-'87. The door shells themselves didn't change much (if at all) for that entire run.
I know the windows changed because I tried putting one from an 84 into my 95 and the arche was different so it was a really tight fit...better than a plastic bag covering the hole though......Luck
