Sponsored by: Real Truck
pedal does nothing
Old Nov 16, 2007 | 05:39 PM
deerhead's Avatar
deerhead
Question pedal does nothing
Hello,
I hope someone can help me.I have a 1998 f350 dual 7.3.Lately the service engine light will come on and my gas pedal stops working.I pump the pedal it does nothing untill the light goes off,only takes a few seconds.This has been going on for about a month but not very often.thanks for any advice.
Old Nov 16, 2007 | 08:40 PM
redford's Avatar
redford
FTE Leadership Emeritus
What do you mean when you say "my gas pedal stops working" ? Does it freeze so you can't push it down? Or, when you push it down nothing happens?
Have you retreived the stored error codes to see what errors are coming off fo the engine?
Old Nov 16, 2007 | 10:46 PM
Cowboy Brett's Avatar
Cowboy Brett
Shooting from the hip, I'm thinking you either have a bad accelerator pedal position sensor (APP) or the wire that supplies power to the APP is broken inside. The APP on the 7.3 is set up the same way that a Throttle Position Sensor (TPS) used to be on the gas jobs, except that it's mounted under the dash on the end of the gas pedal on the diesels.
You can check out the operation of the APP with a multimeter. Resistance should change nice and smooth as you slowly sweep the pedal. If it has any flat spots or cutouts, you've probably found your problem. Otherwise, you're going to have to trace the "reference signal" wire (I don't have the wire color or pinouts with me) until you find the break.
Old Nov 17, 2007 | 04:33 PM
deerhead's Avatar
deerhead
The pedal goes up and down but does nothing.I will look into the APP.I have not retrieved any trouble codes as of yet.Thank you for your advice.
Old Nov 17, 2007 | 06:21 PM
carls 250's Avatar
carls 250
Dorman offers the sensors now also.
Old Sep 28, 2010 | 01:31 PM
LRODEO's Avatar
LRODEO
I am have a similar issue with my 1999 diesel, but i keep blowing a fuse a replace it, than it runs fines than it will blow it again and my pedal has no acceleration, i have replace the pedal thinking that was it but it still keeps happening, i have use two fuses and seems not to last very long. Any ideas
tandpr
Jan 21, 2014 01:11 PM
miller-time90
Jan 17, 2013 11:19 PM
Joshglov
Apr 6, 2010 08:34 PM
DIRTY LU
30
Jun 15, 2009 08:21 AM
slow_v6_stang
Aug 9, 2007 02:23 PM
