Sponsored by: Kumho
4" lift
Old Nov 16, 2007 | 01:54 PM
fballer985's Avatar
fballer985
4" lift
i have a 95 f150 with the 5.0 and i want to put a 4 inch lift on it. i figure 4 in lift springs with add a leafs in the rear but is that all i need or will i need drop brackets and pitman arms and so forth or is 4 the cut off point where i can get away with just springs and leaves?
Old Nov 16, 2007 | 07:13 PM
gnwalker's Avatar
gnwalker
I think 4" is too much without dropping the brackets and definately too much without correcting steering angles. Plus you'll need longer brake lines and possibly driveshafts
