brake system excursion diesel
Old Nov 16, 2007 | 10:58 AM
kjameson's Avatar
kjameson
Need help with brakes, I am constantly having to change the front rotors due to warpage. the brakes start pulsating after changing rotors and pads, is there a solution to this problem?
Old Nov 16, 2007 | 11:25 AM
ZBeeble's Avatar
ZBeeble
One thing to check is the torque on the bolts of your wheels. Believe-it-or-not, incorrect torquing of the wheel nuts causes this problem all the time.
Old Nov 16, 2007 | 12:24 PM
Monsta's Avatar
Monsta
Sit. Stay.
Break in the pad and rotor properly.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Nov 16, 2007 | 06:40 PM
jdw1's Avatar
jdw1
Make sure your caliper pins are not seized in the mounting bracket that the caliper is monted to and the rubber booties are sealing correctly. My left side pins seized and just repaced all brakes and rotors and calipers on the front end of my x with 160000 miles on them!
