Sponsored by: Auxito
Spindle question
Old Nov 16, 2007 | 09:03 AM
DaBossF250's Avatar
DaBossF250
Spindle question
I saw a lift kit for my truck(99 F150 2WD) on ebay that came with 4 new shocks,(2) 3'' spindles, and blocks for the rear. my questions is when I use larger spindles, do I reuse my stock coils? or do I have to buy new longer coils for the 3'' spindle? and oes this kit seem like a good deal for $400?
Old Nov 16, 2007 | 09:51 PM
SYKOLINCOLN's Avatar
SYKOLINCOLN
no lift spindles just have a relocated axle pin for the wheel to ride on, you dont have to replace your stock coils, same rule applies to lowered spindles as well
Old Nov 19, 2007 | 02:25 PM
DaBossF250's Avatar
DaBossF250
are spindles easy to take out and install?
Old Nov 19, 2007 | 07:08 PM
SYKOLINCOLN
not really and yes, Im not to flamilair with 4wd drivetrains, If you've never done something like this before you may want to get someone who does to either help you with it or do it for you, also check with the spindle manufacturer you may have to run a larger wheel for the spindle to fit correctly, if memory serves me right a lowered spindle needs to have a 17 or more size wheel on it
Old Nov 19, 2007 | 08:38 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
His truck is a 2WD. 4WD's don't use coils or lift spindles.
Old Nov 19, 2007 | 08:49 PM
SYKOLINCOLN
well then! ive been told! ok well, same thing still applies!
Old Nov 19, 2007 | 09:03 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Double post....uhhh....almost 30 minutes apart?
