I Am About To Install New Ball Joints In The Front Again After 30,000 Miles , Truck Went For 130,000 On The First Set .driving Habits Are Not Agressive And Last Install Of Joints Were Done Correctly, Is There A Severe Duty Ball Joint Or Any Other Type Or Brand That Is Better So I Do Not Have To Repeat This Repair Again ?
I installed the kit on this page, fourth item down. It's been a year and so far no problems. Truck drives and steers like new and the tire wear is perfectly even.
I have a question, do these 4wd trucks have caster camber adjustments? I'm pulling to the right and wondering if it's something I can adjust out or if I need to take it in?
