Actually, the stock Carter YF 1bbl is rated at around 220 CFM, which is plenty for a stock low revving 300(HP peak @ 3600, not much past it), and a 240(HP peak @ 3900), if the 240 indeed is running one, the 66 I pulled my head from had an Autolite 1100.
1982 F100 SWB
300 HD, 9.5:1 compression 1.94/1.60 valves
Clifford 270H, Hedman Hedder
2½" duals
NP 435/2.75 geared 9"
1985 F150 HD, 300 HD/needs a NP 435/4.10 geared 8.8
70,000 miles
1980 F100 Custom, 300/Np 435/2.75 geared 9"
60,000 miles
