Help!!!!!! Starting Problem?!?!?
Old Nov 15, 2007 | 07:32 PM
Daviddc114's Avatar
Daviddc114
Angry Help!!!!!! Starting Problem?!?!?
i have a 2000 EB 5.4 and i havent started it all day, it was kinda cold, about mid to lower 50's not too bad.. i cranked it and it started and stalled.. it wont hold an idle.. almost like its REALLY COLD.. i got it going by just keep hittin the gas.. when i got it warmed up it stayed running but it barely registered on the tach.. not even the first line... it drives fine but when i take my foot off the gas the tach just dropes.. its not misfiring at alll... could this be a throttle position sensor?? the check engine light is not on???? PLEASE HELP!!!!! My truck never let me down before
Old Nov 16, 2007 | 06:15 PM
ToddRG's Avatar
ToddRG
IAC should be the first suspect.
Old Dec 10, 2007 | 06:03 PM
mister-v-man's Avatar
mister-v-man
Rough idle & engine stall
Have any of you checked the vacuum hose connection to the IAC (Idle Air Control) Valve? My '98 EB Expedition was hard to start and ran really rough. I secured/sealed the hose to the IAC (with some RTV and a wire-tie) and the truck has been running great since. It has 120,000 miles and runs great just like the day we got it. I recently changed the spark plugs on it and have never had to replace a coil pack. For those of you wondering, the vacuum hose to the IAC valve is centered located as far back as you can reach near the top of the engine. It is approximatly 1/2" in diameter, and has a 90 degree elbow on it that looks similar to a small engine spark plug boot. Your hand will pretty much be touching the firewall when you get to it. You'll probably have to stand on a chair and lean over the engine bay to get to it. Make sure it's not loose. The intermittent rough idle could be caused if the hose loosens up during vacuum changes throughout the RPM range. Please let me know if this helps anyone out.<!-- google_ad_section_end --><!-- / message -->
Old Dec 10, 2007 | 06:55 PM
Daviddc114's Avatar
Daviddc114
It was the IAC valve
03trueblue
Aug 26, 2012 09:30 AM
Ford Fx4
2004 - 2008 F150
Dec 18, 2007 07:44 AM
StevensPoint
Apr 19, 2005 08:56 AM
faroffthetrack
May 20, 2004 04:13 PM
pcman
Jul 13, 2002 08:17 PM
