Leaking Injectors
Old Nov 15, 2007 | 07:27 PM
foxdog's Avatar
foxdog
Leaking Injectors
Just noticed that some of my injectors are leaking where they go into the valves. Wha do i do?
Old Nov 15, 2007 | 09:23 PM
94' 460 F350's Avatar
94' 460 F350
you can try and run some injectors cleaner through the tank, or take them out a have someone manualy clean them with a machine
Old Nov 15, 2007 | 09:26 PM
Conanski's Avatar
Conanski
The injectors have O-rings at the top and bottom where they insert into the fuel rail and the intake. You'll have to remove the injectors, clean the rail and intake and install new O-rings.
Old Nov 16, 2007 | 05:00 PM
lostin90s's Avatar
lostin90s
You will need 2 Kits or 16 orings. (my local parts house a "kit" has 8 orings ). light spray with sillycone on reinstall all good . The removale of upper intake will let you can every thing up . Valve covers ,gaskets ,fuel rail ETC later
