6.0 Turbo
Old Nov 15, 2007 | 07:15 PM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE
6.0 Turbo
As some of you know I currently have a superduty down with a blown headgasket. But I have been thinking about changing out that Surging low boost "turbo" on my truck.
I've done searches on 6.0 turbos on 7.3's and I saw a picture of one and had mods listed as a 6.0 VNT turbo with custom control.
The turbo as you all should know has a variable nozzles that decrease lag. These newer garrett VNT's have a oil pressure actuated nozzle control system. It is sorta like the HEUI injection. The set up uses a electronic solenoid to adjust the oil pressure to move the vanes.
Even though the 6.0 is a smaller motor it would probably have greater air flow requirments than a equivalent 7.3 ( im guessing) because of the increased flow rates of the 16valve heads
The promblem is controlling this bugar on a 7.3. In order to create a map for control, I believe you need to know a few parameters from the engine.
Feel Free to add any suggestions
Throttle Position
Engine Load
Engine RPM
Boost
Exhuast backpressure sensor
I'm sure there is a simpler way to obtain these from the PCM but I was thinking of hijacking these signals from an edge programmer unit. Even with these signals we would need a computer to interpret these signals and determine the amount of voltage (0-5 vts i believe) to the VNT soleniod.
I believe its possible.
Old Nov 15, 2007 | 09:41 PM
SolidGround's Avatar
SolidGround
Two words...
Van Aacken.
Seems like a lot of trouble for, well, nothing more than a cool sounding turbo.
my .02
Old Nov 15, 2007 | 09:54 PM
Kwikkordead's Avatar
Kwikkordead
I would keep it simple and limit it to 20 psi.
Have a setup similar to the wastegate on the 7.3 turbo but it moves the vanes instead of a wastegate.
I don't know, but it might tend to stall at low rpm.
It sure would spool up fast quickly that way.
fordpride
15
May 23, 2016 01:00 PM
MC5C
Aug 2, 2014 10:59 AM
fordpride
Jun 26, 2012 10:49 PM
Diesel nut
6.4L Power Stroke Diesel
Feb 9, 2009 12:15 PM
